5 posters
    Add-A-Leafs
    raysxj
    Add-A-Leafs  Empty Add-A-Leafs
    Post by raysxj Sun Feb 16, 2014 7:00 pm
    I know AAL are not as good good as a full spring pack, but Im on a smaller budget then most as im in college.
    I know they make the ride a bit harder and I have heard some people have great luck and some dont, my stock leafs have no sag and are pretty healthy.
    So what im asking is for people who have them or have had them in an XJ, how they felt about them!
    Add-A-Leafs  Empty Re: Add-A-Leafs
    Post by Superduty11 Sun Feb 16, 2014 9:28 pm
    I ran AAL for awhile before going to Dakota springs ride was kind of harsh but if your only going to do mild wheeling they should be ok for awhile
    Post by AllanR Sun Feb 16, 2014 9:47 pm
    I have never had a problem with AAL. I like the stiffer ride my self. (paired with a nice shock) Ifit says 2" Lift it will probably settle down to like 1.5"
    Post by MtnClimber Mon Feb 17, 2014 8:18 am
    If your factory leafs are sagging, AAL's will help get the ride height back to stock+.
    If your leafs aren't sagging yet, I'd recommend installing lift shackles such as RC's 1.5/2" adjustable's.
    IF, your leafs are sagging, and you install AAL's to get stock height +, you can still add some lift shackles to get the desired height.
    When installing AAL's, make sure you use NEW u-bolts!
    My Add-A-Leafs  Twocents_zps49d76ffb
    Post by Guest Mon Feb 17, 2014 8:27 am
    Can I ask why you're looking into getting them? That would better help the group understand the needs and wants of this procedure.
    Is it for looks, function or stance? Have you tried rolling with just a bigger set of tires and seeing if this mix fix your dilemma? Throw us a little more info, and Im sure you'll get some more responses.
    raysxj
    Post by raysxj Mon Feb 17, 2014 10:52 am
    I'm looking for a bit more room to fit 31" tires. The jeep isn't going to be a dedicated trail rig, or need a large amount of flex. It's main use will be dirt logging roads with the occasional rough trail. And it's my DD
    richcz28
    richcz28
    Post by richcz28 Tue Mar 18, 2014 10:14 pm
    Sorry, I'm a little late to this thread.
    I would recommend running an easy inch. These are 1 inch blocks that bolt to the spring pack (much safer than a traditional block). You can use these in addition to your add a leaf.
    I don't know what width your springs are. I run them in the rear of my truck. They also allow axle relocation.
    Even though you are on a budget don't forget the cost of new u-bolts. Lift once and lift right.
    http://diy4x.com/cart/index.php?route=product/product&path=24&product_id=128
      Current date/time is Fri Apr 26, 2024 3:06 pm
