    2022 Ride Requirements
    2022 Ride Requirements Empty 2022 Ride Requirements
    Post by MtnClimber Wed Oct 13, 2021 8:39 am
    All communications will be strictly mobile GMRS, mobile or handheld. Any unit over 5 watts will require a FCC license, FCC Information
    All rides will have a 6 truck/SUV limit. This will help minimize impact on nature by treading lightly and when we are out localvoring
    All rides will be $150$200/truck/SUV. Occupants are limited by the seatbelts
    All rides will share the same simple "Required Equipment" list
    Under the "Required Equipment"
    Rear facing amber dust light that is mounted up high on the rear drivers side of vehicle.
    2022 Ride Requirements Empty Re: 2022 Ride Requirements
    Post by MtnClimber Thu Nov 18, 2021 8:43 am
    NEW 2022 REQUIREMENTS:
    > All vehicles will have a rear facing amber light, mounted in the highest available area on the drivers side of the vehicle. Ideally over the drivers head height to be optimally seen thru the dust. A minimum of size 2"x 3", 18W output, flood or spot pattern.
    2022 Ride Requirements 23690010
    > Vehicle communications will be from a permanent mount mobile GMRS radio with an externally mounted antenna.
    Post by MtnClimber Thu Nov 25, 2021 10:11 am
    Rear facing, steady-on amber dust light that is mounted up high on the rear drivers side (left) of vehicle.
      Current date/time is Tue May 07, 2024 3:47 am
