Howdy All,
Specs:
88 MJ, 4.0L, 5speed, 4X4
I have a95 97 VC on it, allow it to vent into the airbox. Milky oil is coming from it saturating my air filter. Milky oil is also present on the oil fill cap.
Plugs are all burning equal, no visible bad signs there.
Coolant is super green. No loss of coolant is visible.
Oil is fine. Performed an oil change, drove it a hundred miles, no sign of coolant in it.
Compression specs:
Cylinder Dry Wet PSI Difference
#1 110 125 +15
#2 130 140 +5
#3 120 140 +20
#4 125 130 +5
#5 135 135 +0
#6 90 105 +15
Looks I have a ring issue in Cyl#6, but that doesn't explain the milky oil. Any idea's?
Thanks in advance!
Specs:
I have a
Compression specs:
#1 110 125 +15
#2 130 140 +5
#3 120 140 +20
#4 125 130 +5
#5 135 135 +0
#6 90 105 +15
Thanks in advance!
