    Dynamat
    Dynamat
    Post by MtnClimber on Sat Jan 26, 2013 8:20 pm
    So the cab of the Comanche is pretty loud. I'd like to quiet it down and was thinking of different idea's. I saw a Yota that ran it and was thinking 'bout using this on the back of the cab, maybe the roof too.
    Basically wondering what others have used, pro's/con's.
    I also want to sound deaden the floor too.
    Thanks in advance!
    Put a little gravel in your travel.
    It's human nature to want to explore.
    Re: Dynamat
    Post by mike ZJ on Sat Jan 26, 2013 11:59 pm
    I've used Dynamat with good results. Get the thicker stuff for the flatter areas. Then use the thin stuff for curved areas, it'll be alot easier to work with. Theres alot of cheaper knock offs on ebay that would save you some money, maybe worth a try. It also insulates quite well.
    Re: Dynamat
    Post by 99BlackClassic on Wed Feb 06, 2013 9:23 am
    Not sure if you want to do this to this rig but wouldn't undercoating or bed line work?
    Re: Dynamat
    Post by MtnClimber on Wed Feb 06, 2013 10:01 am
    That would hafta have some sound deadening qualities to it. Whatever I use will be covered up with either a rubber floor or carpeting. I'll hafta check what the quietness of bedliner would have Wink
    Re: Dynamat
    Post by Barrows on Wed Feb 06, 2013 10:41 am
    Bed liner has very little sound dampening in my experience. I have looked in to Lizard Skin, because it is made as a spray on sound deadener. I might spray that in this summer then reapply the Raptorliner on top.
    Re: Dynamat
    Post by 99BlackClassic on Wed Feb 06, 2013 6:48 pm
    I wasn't 100% sure just going on something I think either I saw or heard someplace.
    Prepared Associates
    Re: Dynamat
    Post by Prepared Associates on Wed May 08, 2013 4:47 pm
    When I built the storage compartment for the extended cab of my truck, I pulled the carpet up and put down some kind of roofing material, the name escapes me, that I got from Home Depot.
    It was some kind of vinyl with a really sticky adhesive backing. Prior to putting it in, the road noise coming from the back of the truck was terrible. It seems to work pretty well.
    Dampened the noise well enough. If you have the extra cash, I would just get the Dynamat.
    wntrcmpr
    Re: Dynamat
    Post by wntrcmpr on Wed May 08, 2013 5:55 pm
    Prepared Associates wrote:When I built the storage compartment for the extended cab of my truck, I pulled the carpet up and put down some kind of roofing material, the name escapes me, that I got from Home Depot.
    Grace. Ice and water shield ?
    Prepared Associates
    Re: Dynamat
    Post by Prepared Associates on Wed May 08, 2013 5:57 pm
    Yep, that's it!
    x-plorenow
    Re: Dynamat
    Post by x-plorenow on Sat Sep 28, 2013 7:42 pm
    Dynamat works great, I used it all the time in my car stereo teen years. But it is very expensive.
    I have heard good things about Al's floor liner, and heat and noise reducer. I pulled the carpet on my JK and plan to use this soon to treat the floor.
    Re: Dynamat
      Similar topics
      Current date/time is Fri Feb 23, 2018 6:59 pm
