In all the wiring and updating. I have a Ground issue from the dash. All my gauges flicker and act up when I use my turn signals, lights and/or radio ect.... Where should the Ground for the dash be location and where is it coming from? Any help would be great.
3 posters
87 dash gorund issue
scyr87yj- Posts : 185
- Post n°1
Hubie- Posts : 29
- Post n°2
Re: 87 dash gorund issue
You might check the fuse block to make sure you have a good solid ground there. Most of the dash panel stuff is grounded through that box.
Silvanus- Posts : 170
- Post n°3
Also the dash gauges are linked by an contact tape, when it ages it tends to shrink and warp, thus pulls away the contact area of the gauges. I bet if you take a look you'll see that they have crinkled up!
There's a company that makes replacement backing tape just Google for it!
- Post n°4
I will check those. The dash has been apart so many time i am sure the contact tape is none existent. Noe the ground for the fuse back is located next to is i assume?
Hubie- Posts : 29
- Post n°5
Most fuse blocks are grounded by the bolt/bolts that attach them to the body/firewall. You'll have to look at yours to be sure. I haven't seen one with a separate ground wire, but that doesn't mean it couldn't be that way!
